1 - 15 of 15 Posts
So I have replaced my rotors twice now with cheap chinese replacements. Within a few years they always warp. I have finally decided to spend the money and buy good ones, but there are a lot of options. What are the best ones to get, Brembo, Bosch, Volvo original, Zimmerman???
I have had good luck with centric rotors.
I had a good set of Centrics on my 855 as well.
Although I wonder if there is something else going on? Rotors don't typically warp anymore. Usually what happens is you get some pad buildup on the rotor that turns into a permanent high spot. Avoid parking the car in the wet for an extended period of time without driving it if at possible.
I have used Centric, Zimmerman, Stoptech, Brembo, Bosch, OEM. I think they are all fine. I live in a northern climate so prefer ones that have a zinc coating to keep the rust on the rotor hats down a little.
I have had good luck with the Meyle rotors. They also have a nice zinc finish so they don't rust. No warping issues at all and the price is very nice compared to OEM, Brembo, etc.
OEM is ATE. Zimmerman is a good high quality. Brembos arent anything special for our p80 cars.
I think the cheap rotors could warp if your over tightening your lug bolts.
'12 S60 T5
I've gone with ATE with all my replacement, and haven't had a single complaint about the rotors, worth the money in my opinion.
Try ebay.
FCP has the best prices on rotors, on sale now too.
I am extremely happy with Stop Tech/Centric rotors and pads from Amazon. They were cheap-ish too!! I have not read good things about the Brembos.
Sent from my Nexus 4 using Tapatalk
Low end brembos are junk. Corrode badly and start to get deposits pretty quickly. ATE is oem, not very expensive. Zimmerman is high quality zinc coated. Those are what we run after the brembo debacle and couldn't be happier
I've had good luck with ebc rotors had them on my 850 for 3 years now with ceramic pads. Holding up well.
Anything Zinc coated should be better than stock. I'm very happy with the Zimmermans on my V70.
1 - 15 of 15 Posts
