1 - 20 of 42 Posts
Just had my clutch replaced. 75,000 miles on my '04 V70 R. $2,300.00. Yikes. They said that knowing how anal I was about my R, it was recommended that I replace the two piece dual density something flywheel at the same time. Job is done, car is back to its great self. So when you are dumping your clutch at 4,500 or higher rpms, be warned that it is not a $750 clutch you are smoking. oclv
Re: Be kind to your clutch (NRM8573)
I would guess about 1500 in labor
Re: Be kind to your clutch (JRL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">I would guess about 1500 in labor</TD></TR></TABLE><p>That's 20 hours at my dealer's $75 rate. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0">
Re: Be kind to your clutch (oclv)
sounds a bit high, but not by much. I got a new clutch installed when my tranny was replaced under warranty for about $800. the clutch was ok, but it would have cost much more to replace later as the whole tranny has to be dropped for the operation.<p>I thought the clutch was a fairly self contained unit however, didn't know that the flywheel was a seperate item.
Re: Be kind to your clutch (vizwiz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>vizwiz</b> »</i></TD></TR><TR><TD CLASS="quote">sounds a bit high, but not by much. I got a new clutch installed when my tranny was replaced under warranty for about $800. the clutch was ok, but it would have cost much more to replace later as the whole tranny has to be dropped for the operation.<p>I thought the clutch was a fairly self contained unit however, didn't know that the flywheel was a seperate item.</TD></TR></TABLE><p>so you are saying in order to avoid a high repair bill, i should beat the crap out of the tranny so it fails, then have it replaced under warranty, and while it is out, conveniently ask to have the clutch replaced?! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: Be kind to your clutch (MagoonR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>MagoonR</b> »</i></TD></TR><TR><TD CLASS="quote">That's 20 hours at my dealer's $75 rate. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"> </TD></TR></TABLE><p>12 hours @125 an hour...<p>vadis has it listed as a book rate 11 hour job... engine, tranny, pretty much everything has to be taken apart...<p>
More dealers are over 100 now
Re: Be kind to your clutch (SilverS60RNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>SilverS60RNYC</b> »</i></TD></TR><TR><TD CLASS="quote"><p>12 hours @125 an hour...<p>vadis has it listed as a book rate 11 hour job... engine, tranny, pretty much everything has to be taken apart...<p></TD></TR></TABLE><br>I'm sure the flywheel cost a bit
I guess I'll put the money aside. It's actually pretty cheap considering it's for a high dollar performance sadan.<p>Any high performance clutches out there? I did a search I google and turned up empty.
Clutch kit: $287.<br>Flywheel: 422.<br>Control Cylinder 160.<br>seal ring 33.<br>Screw 29.<br>Transmission O 81.<br>Labor 1,253.<p>I think they mentioned it was 14 hours of labor. <p>oclv
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">More dealers are over 100 now</TD></TR></TABLE><p>True, the service loaners and the cappucino machine and internet access in the waiting room aren't exactly free.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>oclv</b> »</i></TD></TR><TR><TD CLASS="quote">Clutch kit: $287.<br>Flywheel: 422.<br>Control Cylinder 160.<br>seal ring 33.<br>Screw 29.<br>Transmission O 81.<br>Labor 1,253.<br></TD></TR></TABLE><p>Putting up with 2+ years of kindhearted abuse for owning a GT, and then realizing that this is $2,000+ that I won't have to spend .....<p>Priceless!<p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> <p>-Ben
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>oclv</b> »</i></TD></TR><TR><TD CLASS="quote">Clutch kit: $287.<br>Flywheel: 422.<br>Control Cylinder 160.<br>seal ring 33.<br>Screw 29.<br>Transmission O 81.<br>Labor 1,253.<p>I think they mentioned it was 14 hours of labor. <p>oclv</TD></TR></TABLE><br>Think I was reletively close there in my estimate <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> (Didn't think the flywheel was quite that much) <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>oclv</b> »</i></TD></TR><TR><TD CLASS="quote">Just had my clutch replaced. 75,000 miles </TD></TR></TABLE><p>75k miles on one clutch! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">More dealers are over 100 now</TD></TR></TABLE><p>I guess that I am getting a bargain then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>MagoonR</b> »</i></TD></TR><TR><TD CLASS="quote"><p>I guess that I am getting a bargain then.</TD></TR></TABLE><br>Yes you are. One of the benefits os living in the boonies <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote"><br>Yes you are. One of the benefits os living in the boonies <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> </TD></TR></TABLE><p>Yup. Good old Pennsyltucky. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0">
1 - 20 of 42 Posts
