1 - 2 of 2 Posts
· Registered
Ok I've got the modulator in, and I have all of the stuff I need to do the Modulator install, but I have some questions for the people who have done it before. i have an S40.
1. Did you just use tap in connectors to connect to the cigarette lighter power. I think I'm going to try to run it to the cigarette lighter in the back.
2. If I need to extend the wires, do I have to solder them them together. Or can you just wrap the exposed ends and then wrap with tape.
3. I have done most of the stuff, but I have very little wiring experience. So any extra info you have would help.
· Registered
Re: Basic iPod Modulator Wiring question? (Lou3000)
1) Don't use the lighter in the back. It doesn't turn off with the ignition. I ran mine to the front lighter
2) I just used tape.
3) If you search the forums there's a ton of info on this topic. Literally everything you need to know. Good luck.
1 - 2 of 2 Posts
