Today I was replacing my LCA bushings with PowerFlex. Everything went well but I needed to replace my ball joint at the same time and thats where the problem came in. I cant get it in place, not deep enough. As you can see at the picture I'm missing at least 5mm.
I've tried to sledgehammer, crowbar and such. Even put the wheel back on and lowered the car with it not fully seated and hoped for it to pop in place but no luck. I also slightly tried to pull it together with the bolts but I read in another thread something about not doing that to much because you can destroy the bolt-threads and get yourself in big trouble.
Whats the trick to get in in place?
