Volvo S60, 2011, 2.0
Good evening to all! Yesterday I’ve made the oil change and after I put the new oil according to the manufacturer's specifications (5.9 liters) the level had to be at the maximum limit, but it isn’t. When I check the oil level, it has only a dash above the minimum limit, although I put exactly how much is written in the car manual. Has anyone encountered this problem before? I specify that it is a Volvo S60 D3 engine code D 5204T2 with electronic oil level display.
I'm not sure about the diesel engines, but with the gas/petrol engines in VIDA/Service Function menu there is a "Reset oil level after service" feature.
I believe the idea is when you have changed and refilled the oil to specs it will reset the oil level sensor readings.
