1 - 14 of 14 Posts
Suddenly got a bunch of errors, going to take it tomorrow to a dealer, will see whats going on with my baby
99% of the time, that's a dead battery.
I dont think its a battery, i think something with brakes and abs sensors, because when i turn and slightly pres brake i feel abs engage for no reason. All those errors i've got on a highway
i vote battery too. 3+ years old, cold winter temps...
Ok, will see tomorrow ))) but it always starts good
Bad battery or battery grounds need to be cleaned.
The battery is probably tripping the ABS system.
BTW, when did C70s get those gauges? I like the thick silver surrounds!
With facelift in 2011
Just picked up a car from a dealer. The problem was that left front wheel bearing out of hub and was triggering all those codes.
cool, thanks for sharing. no bearing grinding noises before all the codes?
wow, you got a good one. mine has been replaced twice, also a 2008. pretty much at 3 years on the dot...started with weird codes and then a few days later starting problems
The battery in my 2008 lasted 5 years with Michigan winters but YMMV.
Discussion Starter · #13 ·
Nope, a little noise came later but hardly noticeable
BTW dealer had all paper work with my problem, so it was known to them
You are the 1% of the time that it's not the battery. Glad it's fixed though.
1 - 14 of 14 Posts
