1 - 14 of 14 Posts
Anyone have any ideas my back up sensors stopped working. I seem to find anything online or anywhere. Thanks.
Discussion Starter · #2 · (Edited)
Someones gotta know something or have a idea.
Broken wires most times. My dealer used to just fix it for free when I went in.
Mine is currently not working, but occasionally does. So yeah...I'd ASSume broken wires.
Was that an option or maybe only '05+ cause I never realized that these cars had that. Makes me wonder if mine is just broken. :)
wires behind the bumper? is there a fuse for them? thanks.
Not sure does ur rear bumper have the sensors sticking out?
Check for the round discs on the rear bumper and you should have a button with a "P" next to your DSTC button if you have it. I think it only became available starting in '06 but I'm not positive.
Ok I noticed my reverse lights don't work also. I had my clutch and flywheel done and angle gear. I asked the shop and they said they did not unplug anything. I'm sure it's gotta be something stupid to loose back up sensors and reverse lights at the same time please help. Also the inside of the car was not touched. I'll bring it back to the shop if I got to but would rather fix it myself if anyone knows what going on with it thanks.
If this happened after the shop looked at the car, then it's their responsibility to fix it for free.
R's have back up sensors? If so my sensors never worked-was this an option or standard?
Probably the reverse switch died. They do unfortunately go from time to time.
Easy enough to replace, it sits on top of the transmission with the cables.
Discussion Starter · #13 ·
Anyone have a part # or is there anyway to check it?
1 - 14 of 14 Posts
