1 - 20 of 210 Posts
I went to my dealer again with the axle ping noise problem.<br>2 months ago they made something like s silicone but the noise again was heard last week.<p>This time they used the XC90 axle screws according to the bulletin and seems that this will solve my problem for a long time.<p><A HREF="http://imageshack.us" TARGET="_blank"><IMG SRC="http://img50.imageshack.us/img50/904/image10al1.jpg" BORDER="0"></A><br>
Re: Axle Ping Noise repaired with a new Axle Screw with rubber.... (xenophobic)
AHA, so that's what is different about this part. Thanks for the pic.<p>The reason they'll work differently is because they add some pressure to the spline ring. The "ping" isn't looseness in the splines, it's end play in the joint, as the ring moves in and out. Loctite holds it until it lets go, this pad will stay there full-time.<p>Tom.
A few of us have already had this done....and so far so good. For me, it took two loctites and hub replacement before the field rep tried this fix. I am glad to see that the word is spreading.
yup, this was applied to mine since 2004. No problems since then..<p><A HREF="http://forums.swedespeed.com/zerothread?id=21132" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=21132</A>
Writing up my request to my service adviser now. <br>This will be the third time they have glued/fixed it in 18K miles. Sounds like an electrical storm on mine when accelerating along with the normal slow speed ticks or pings. <p>- Polartek
Hi,<p>I have an 04 S60R. I am reading all of the related R forum posts trying to find out what the TNN # is (or other bulletin #) to fix the axel spline problem.<p>Any help would be much appreciated.<p>Thank you.<p><br>
Re: Axle Ping Noise repaired with a new Axle Screw with rubber.... (wineconnoisseur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>wineconnoisseur</b> »</i></TD></TR><TR><TD CLASS="quote">I have an 04 S60R. I am reading all of the related R forum posts trying to find out what the TNN # is (or other bulletin #) to fix the axel spline problem.</TD></TR></TABLE><p>Welcome to the board. Here are the two TNN's:<p>S60/S80/V70<p><A HREF="http://www.alldata.com/tsb/Volvo/1080201600000_1114758000000_TNN77-08/77081.html" TARGET="_blank">http://www.alldata.com/tsb/Vol....html</A><p>XC90<p><A HREF="http://www.alldata.com/tsb/Volvo/1080201600000_1114758000000_TNN77-09/77091.html" TARGET="_blank">http://www.alldata.com/tsb/Vol....html</A><p>As you can see by this thread, the XC90 fix seems to be a better solution.
Re: Axle Ping Noise repaired with a new Axle Screw with rubber.... (MagoonR)
Magoon,<p>Thank you for the information. I will take both to the dealer.<p>I want them to do the XC90 fix but I fully expect them to resist performing a "non-S60R" procedure. <p>Does anyone have any guidance (or better yet experience) they could share with me about how this conversation could go?<p>Thank you ver much.<p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>wineconnoisseur</b> »</i></TD></TR><TR><TD CLASS="quote">Does anyone have any guidance (or better yet experience) they could share with me about how this conversation could go?</TD></TR></TABLE><p>Explain that you are experiencing the pinging and would like the loctite fix and the bolts replaced. They will push back on the bolts as "non R' but I can email you a pdf of my invoice that shows it can be done.
Great write up and thanks for the picture. I have had mine done (loctite) 2 times in 20,000 miles. Now I will bring this post in and let them tell me the XC90 fix will not work on my R. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>MagoonR</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Explain that you are experiencing the pinging and would like the loctite fix and the bolts replaced. They will push back on the bolts as "non R' but I can email you a pdf of my invoice that shows it can be done.</TD></TR></TABLE><p>MagoonR, could you send me a copy of that PDF. My dealer is refusing to even acknowledge there is an alternative fix. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/mad.gif" BORDER="0"> <p>-Will
Re: Axle Ping Noise repaired with a new Axle Screw with rubber.... (Rangeball)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Rangeball</b> »</i></TD></TR><TR><TD CLASS="quote"><p>MagoonR, could you send me a copy of that PDF. My dealer is refusing to even acknowledge there is an alternative fix. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/mad.gif" BORDER="0"> <p>-Will </TD></TR></TABLE><p>I would like one too please. [email protected]<br>
I just had the loctite fix. I showed the dealer both TNNs and the service manager knew exactly what to do but did the loctite only for now. So far, the car is so different. It drives smoother without the horrendous backlash from 1st to 2nd and no more clunking. <p>The dealer even took the bracket off when I asked.
Re: (dhdd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>dhdd</b> »</i></TD></TR><TR><TD CLASS="quote">I just had the loctite fix. I showed the dealer both TNNs and the service manager knew exactly what to do but did the loctite only for now. So far, the car is so different. It drives smoother without the horrendous backlash from 1st to 2nd and no more clunking. </TD></TR></TABLE><p>Give it time. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Rangeball</b> »</i></TD></TR><TR><TD CLASS="quote"><p>MagoonR, could you send me a copy of that PDF. My dealer is refusing to even acknowledge there is an alternative fix. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/mad.gif" BORDER="0"> <p>-Will </TD></TR></TABLE><p>I have always wanted to quote myself. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"> <p>Anyways. SOOOOOO, I just got back from the dealership. They refused to acknowledge the XC90 bolts work even though I am showing them the invoice that MagoonR gave me. Stating the reason why (I am going to quote because it will make this a lot more fun to read) "the 04's have different parts than the 05's." <p>This might be true not trying to knock the tech if he is correct, but then he turns around and looks me straight in the face and says "man your car looks good. (and I quote) I thought for a moment that you had lowering springs but then I realized you just had spacers." After saying thank you and walking out the door, I realized that the guy can't read the Eibach printed on my springs. No wonder he can't read the TNN I gave him about using XC90 bolts to fix the axel spline. Un-be-freakin-lievable! <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"><p>To top it all off, they fixed my broken turn signal and it still doesn't work!<p>I need a <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0"> then a <IMG NAME="icon" SRC="http://********************/smile/emcocktl.gif" BORDER="0"> but not a Martini something along the lines of bourbon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Rangeball</b> »</i></TD></TR><TR><TD CLASS="quote">Anyways. SOOOOOO, I just got back from the dealership. They refused to acknowledge the XC90 bolts work even though I am showing them the invoice that MagoonR gave me. Stating the reason why (I am going to quote because it will make this a lot more fun to read) "the 04's have different parts than the 05's." </TD></TR></TABLE><p>Bleeping numbskulls. Here's a link that CLEARLY shows the fix on an 05. <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> <p><A HREF="http://forums.swedespeed.com/zerothread?id=40804&page=3" TARGET="_blank">http://forums.swedespeed.com/z...age=3</A>
I'm having the axle click problem now, and I passed along all the info I gathered from here on the topic, including a copy of the pdf invoice showing the XC90 axle bolt fix. My local service rep needed a few days to talk to the regional rep, and he said that regardless they have to try the loctite fix first. <p>He said the loctite needs to cure for 6 hours with the car up on a hoist, and if it's taken down before that then the fix will not take. His opinion was that maybe the stories I heard about the fix failing could be due to inadequate cure time on the hoist. You guys all seem pretty knowledgeable about S60R issues so I don't know if that is accurate, but I don't have much choice in the matter.<p>I take it in for the Loctite fix next week, I'll keep you posted as to whether it lasts!<p>gb
When I take my car in for it's first service (dreading it) I will demand they use the XC90 bolts and bushings otherwise I won't bother having them fix it at all. I usually get my way though so hopefully this will be no different. It's just stupid that a fix that works and doesn't need to cure is not being used as standard. Just an FYI but my car has had the axle ping since the day I got it... I had no idea what it was until I found out about it here...
Re: (grimmbob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>grimmbob</b> »</i></TD></TR><TR><TD CLASS="quote">My local service rep needed a few days to talk to the regional rep, and he said that regardless they have to try the loctite fix first. </TD></TR></TABLE><p>Have them perform the loctite fix but while they're in there, swap the axle bolts. I think they have to come out anyway.<p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>grimmbob</b> »</i></TD></TR><TR><TD CLASS="quote">He said the loctite needs to cure for 6 hours with the car up on a hoist, and if it's taken down before that then the fix will not take. His opinion was that maybe the stories I heard about the fix failing could be due to inadequate cure time on the hoist. You guys all seem pretty knowledgeable about S60R issues so I don't know if that is accurate, but I don't have much choice in the matter.<p>I take it in for the Loctite fix next week, I'll keep you posted as to whether it lasts!</TD></TR></TABLE><p>Both loctitings sat at the dealership overnight....and neither lasted. Good luck.<BR><BR>
<i>Modified by MagoonR at 11:27 AM 8-2-2006</i>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Rangeball</b> »</i></TD></TR><TR><TD CLASS="quote"><p>I have always wanted to quote myself. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"> <p>Anyways. SOOOOOO, I just got back from the dealership. They refused to acknowledge the XC90 bolts work even though I am showing them the invoice that MagoonR gave me. Stating the reason why (I am going to quote because it will make this a lot more fun to read) "the 04's have different parts than the 05's." <p>This might be true not trying to knock the tech if he is correct, but then he turns around and looks me straight in the face and says "man your car looks good. (and I quote) I thought for a moment that you had lowering springs but then I realized you just had spacers." After saying thank you and walking out the door, I realized that the guy can't read the Eibach printed on my springs. No wonder he can't read the TNN I gave him about using XC90 bolts to fix the axel spline. Un-be-freakin-lievable! <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"><p>To top it all off, they fixed my broken turn signal and it still doesn't work!<p>I need a <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0"> then a <IMG NAME="icon" SRC="http://********************/smile/emcocktl.gif" BORDER="0"> but not a Martini something along the lines of bourbon.</TD></TR></TABLE><p>Here I go again quoting myself again. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"> <p>After allowing myself to sleep on the matter and tackle it with a level head I was able to speak with the service manager, who is normally my point of contact and a very reasonable guy. They decided that they will try the XC90 bolts after they measured them and determined that they will work. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> Apparently my serive manager is still explaining it to the knuckle head tech. See above!<p>Thanks MagoonR for the invoice and advice, if anything it was a learning experience. I know my dealership thinks I am a PITA but I shouldn't have to argue over simple fixes. Especially ones where I am showing them an invoice!! <p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0">
1 - 20 of 210 Posts
