hit an animal in the road the other day, knew nothing of the bracket of death. going down the road the next day i heard metal on metal action underneath my car (just bought it used 1 month ago) got to work and looked under the car to see the bracket bent like something had wedged itself in there but whatever it was, was no longer there. had already set up an appt at my local volvo dealership for a tune up and sunroof module install the next day. got to the dealership told them what had happened and what i had noticed, so they got to work on the tune up and the module install 3 hours later i got back to the dealership he didnt call me or anything to tell me what was wrong with the bracket or if it had been fixed he simply told me to follow him. got to my car and it was already back down on the ground, bracket was off. he told me he was going to find a tech to put the car back up in the air so i could see what was wrong with it. after about 10 min of looking for someone he figured out everyone had went home. he then stated that quote "COLLISION IMPACT WITH SOLID OBJECT, CAUSING DMG TO
EXHAUST SHIELD WHICH WAS PUSHED UPWARD INTO EXHAUST SYSTEM WHICH WAS
PUSHING UPWARD ON THE DRIVE SHAFT. DUE TO THE CHANGED ANGLE OF THE
DRIVE SHAFT, DMG TO REAR BEARINGS & GEARS INSIDE TRANSFER CASE." he then quoted me 4000 dollars to fix LMAO anyone want to help me out with a do it yourself fix or any info on refilling the transfer case with fluid as it has leaked out and how much play the driveshaft should have. or any noises it would make the car drove fine it only made a little noise when you turned and drove after he removed the braket i have pictures too if that would help. i would appreciate any additional feedback....ps sorry this is such a long post http://forums.swedespeed.com/z...id=51#
