I have posted this within threads, but it gets lost. So here it is again.<p>If you suspect an angle gear or any AWD issue...<p>1- jack up one (only) front wheel<br>2 - put car in neutral<br>3 - by hand, turn the wheel in the air<br>4 - observe drive shaft, it should turn<p>If 4 fails, the angle gear or transmission is faulty.<p>Method used here -> <A HREF="http://forums.swedespeed.com/zerothread?id=71751&postid=704389#704389" TARGET="_blank">http://forums.swedespeed.com/z...04389</A><p>
