Hey all,
Have a 2007 Volvo XC70 w/136K miles. Car is very clean, and has been very well maintained. When the car is cold, it drives/shifts totally well. However after ~20 minutes of driving, it starts to experience a slightly rough/harsh downshift, mostly in 3-2, but sometimes it's 2-1. Has delayed engagements/rough 'garage' shifts, P to D, D to R, etc. Doesn't slip or flare, but sometimes the 2-3 shift could be harsh. Some downshifts are good, sometimes it acts up.
Fluid isn't horrible, but def could use a 3 x drain & fill. From talking to my mechanic, some research and reading, it looks to be a Valve Body issue (perhaps just the solenoids). The mechanic I took it to said there weren't any transmission related codes in VIDA.
So I have a few questions/looking to get some thoughts/feedback on others' experience.
1) Will a bad valve body always trigger codes?
2) Per my mechanic, my biggest gamble here would be if the transmission turns out to have internal clutch wear/failure. Is that common/what is the likelihood, what would symptoms of that look like?
3) When I google AW55-50 Valve Body, I come across remanufactured units like this one: AW55-50SN AW55 50 Re5f22a aw55-51sn Nissan Maxima Altima Quest Volvo Complete Transmission Valve body Remanufactured Lifetime Warranty. Is this a reputable seller, if not where would you all recommend I look? I did come across a local shop that sells reman'd units for $570: Valve Body Pros AW55-50. Both technically offer lifetime warranty, but what could the difference be between the 2?
Any other thoughts, suggestions or experience would be appreciated! Thanks
