1 - 9 of 9 Posts
Discussion Starter #1
Does anyone know how much hp a auto fwd p2 can handle?
Discussion Starter #3
Don't know about hp, but according to Wikipedia's entry for the Aisin AF33 (5-speed automatic), it can handle up to 310 ft·lbf (420 N·m) of torque.
I hope it can handle 300whp :)
Only one way to find out...
300whp is my goal for my AW-55 FWD 2.5T once I get my 16t and tune, so I hope so too.
Discussion Starter #5
I'm so close.. I just need injectors and tune now... I don't think a 16t can produce that much power though
Well by the looks of it you are much closer than me to that goal. My goal is more of a wish, and my plans of getting a 16t and a tune are still in their earliest stages. I'm still bone stock right now, working on Stage 0.
Discussion Starter #7
If you decide to go bigger with the turbo do the 19t or 20t conversion. Easiest thing to do. I only spend $360 turbo my 13t into a 19t w/11 blade turbine wheel. I can't wait until tune and throw everything in.
Thanks for the heads up! I will look into that.
Just remember that only a 13/16/18T can be made into a 19T. My 2.5T had a 14T which isn't interchangeable (the hotside is smaller and won't fit) so you'll have to get the whole turbo. Still it's only $20 more than a 16T which is a large reason I went for the bigger upgrade off the bat. I did consider a 16T before my swap, but figured I wouldn't want to pay and do the work to swap in a 16T and then a 19T down the road.
1 - 9 of 9 Posts
