1 - 13 of 13 Posts
bringing in our 04 v-70 asr for its' 30 k free service....I have read where some of you are recomending tranny flush around 30k...is this something I should have the dealer do??? I realize I have to pay as it is not recomended service. ( ps it is a nj flatlander car no towing no heavy loads...50/50 highway/ city)
Re: automatic tranny flush (ee778a)
Have a trustworthy independent do it and use Redline D4 ATF. It costs only 9.50/qt vs 17.30/qt from the dealer. Plus labor will be less expensive. You can buy the Redline from iPd. I noticed an imediate difference after flushing my fluid.<p>They (iPd) are awesome and the fluid works great.<p>
Re: automatic tranny flush (EBender1965)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>EBender1965</b> »</i></TD></TR><TR><TD CLASS="quote">Have a trustworthy independent do it and use <B>Redline D4 </B>ATF. It costs only 9.50/qt vs 17.30/qt from the dealer. Plus labor will be less expensive. You can buy the Redline from iPd. I noticed an imediate difference after flushing my fluid.<p><br></TD></TR></TABLE><br><B>NO NO NO</B> <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> unless you want your tranny to expire.<br>THE ONLY FLUID RECOMMENDED BY ASIAN WARNER (and Volvo) IS THAT MOBIL, (can't remember the number)ATF<br>You do that and you have a (tranny) problem under warranty, they will tell you to go pound sand<br>DO NOT tell people to use any fluid but the Mobil.<br>You want to experiment on your car, go ahead but do NOT tell some innocent owner to use RedLine.
Re: automatic tranny flush (JRL)
JRL is correct according to my dealer, lawrence volvo in walnut creek ca.<p>the Mobil ATF 3309 is acceptable to them. i took some in and it was evaluated by the tech staff. they accepted that it is the same specification for the volvo asin warner transmisssion (5 speeds). the earlier cars, 4 speed auto can use the other fluids according to them.<p>But the 55-50 must use volvo or the mobil atf 3309 fluids. they both have special friction modifiers for this tranny. it is $4 a quart at many good suppliers.<p>there is a thread somewhere on here that goes into more detail.<p>JRL is right. period. . . .
Re: automatic tranny flush (hastee)
Thanks for the number (Mobil) forgot it.<br>It's not just your dealer, it's EVERY dealer.<br>There is this huge bulletin, my service manager showed it to me.<br>The stuff Volvo sells (inflated, of course) <B>IS</B> the Mobil, repackaged
Has anyone flushed a newer model? (I've done my 98 a few times with no issues). The reason I ask is that the connection to the cooler looks different then my 98.
Re: automatic tranny flush (geo1)
geo1,<p>I did our '01 V70 about 10K ago. Easy DIY if you're even mildly mechanically inclined. I followed a great step-by-step I've been searching for since I saw your post; maybe someone knows where to find it? The connection to out-flush is a green plastic fitting on the driver's side of the transmission fluid cooler. Pinch & pull. Fill through the dipstick hole. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/cool.gif" BORDER="0">
Re: automatic tranny flush (Steely)
Steely,<p>Thanks!! I see the green plastic clip so I'll follow your advice and remove the line. Once thats out I'll follow the same procedure that I use on my 98 S70.<p>Thanks!<p>George
geo1,<p>As usual, I hid this link from myself:<p><A HREF="http://www.v70xc.com/forums/showthread.php?s=b0beaa91de733300ed3d7621e07745a8&t=5668&highlight=transmission+flushing+home" TARGET="_blank">http://www.v70xc.com/forums/sh...+home</A><p>Pictures & ever'thang.<p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/cool.gif" BORDER="0">
Is the Mobil 3309 ok to use on the earlier 4-spd trannies ('98 V70XC), or should I go w/ the Redline?
Re: automatic tranny flush (Mk1Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Mk1Racer</b> »</i></TD></TR><TR><TD CLASS="quote">Is the Mobil 3309 ok to use on the earlier 4-spd trannies ('98 V70XC), or should I go w/ the Redline?</TD></TR></TABLE><p>There's much discussion on that here....unfortunately with different opinions. Anyway, read the entire thread which includes some official Volvo documentation. <p><A HREF="http://www.matthewsvolvosite.com/chat/phpBB2/viewtopic.php?t=3951" TARGET="_blank">http://www.matthewsvolvosite.c...=3951</A>
Re: automatic tranny flush (MadeInJapan)
I read that thread, which is what precipitated my question. I spoke w/ the local Volvo Stealership, and was told that my takes normal Dexron/Mercon III, not the synthetic (Mobil 3309)
I agree. However I don;t thinkt he Mobil will hurt the earlier trannys but it WILL hurt using the Daxtron on the later 5 speeds. YOu mUST use the Moil on those AsienWarners
1 - 13 of 13 Posts
