Re: Auto up/down window switch (enVious)
Yep, it's most likely the pinch sensor out of alignment. Had this problem once, can't remember why, it just started happening ('05 XC90, driver's side). Think you'll find, if you move the switch and hold it (or twitch it) once it's up, it will stay up but auto will not work on it's own. While techs were sorting this out, one of them mentioned the possibility of holding the button in up position after window closes for 45 seconds or so. Think this works for the rears and may work for the fronts but it was near closing for the dealer and there wasn't too much time to play with it. At any rate, after a few failed attempts, VADIS window reset was the answer but there was some talk that holding it might have in fact resolved the issue. Been awhile but that's what I recall and could be worth a try before heading back to the dealer...
