1 - 6 of 6 Posts
Does anyone know where I can find an automatic transmission shifter for a 98 V70, non turbo? I checked some websites but no luck, I would like to know of other options before paying a premium price at the local dealer.<p>The problem: the shifter button is starting to stick and prevents me from putting the car in the "park" position and cannot remove the key. The sticking problem just began 2 weeks ago. The car has 128K.<br>Thanks for any help.
Re: Auto Trans shifter (mssurfn1)
I had two solutions...<p>Put the shifter in L or whatever is the furthest back, then that button, pull the button outward, and you can stick the stick of a WD-40 spray can and spray some in there... then put the button in and out a few times till it loosens up. <p>the other solution is that the stickiness might be caused by the leather wrapped part has become loosened inside. you can try lubing it with some Wd-40/or a vynyl treatment (vynylex) or try to take a pic, and fish out the leather and cut the excess piece off. I did that with mine and havent had a problem since...<p>I THINK this is what you are talking about....
Re: Auto Trans shifter (GShyneDM)
oh and to remove the key, put the shifter in P, and bang the back of the handle... the button should pop out. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
Thanks for the remedy. I like the caveman version of banging the shifter to pop out the button. (note: I did the research and there are no cavemen around, however "caveman" types abound).<br>Thanks again.
WD-40 worked for me and keeps working after doing it to it over a year ago.
I too have had this problem on and off. The WD-40 is a fix but you can also try spraying compressed air in there which works.<br>Also you can remove that center console and spray the line going into the shifter to remove any gunk in there which causes this sticking.
1 - 6 of 6 Posts
