Hi. 98 V70 GLT. I need to change the trans fluid. I have a question about the procedure. I need to remove the auto trans low pressure line from the radiator. I belive it's on the drivers side but I don't know if it is the top or bottom line. Anybody know?
Thanks for any help,
Eric
Re: Auto Trans fluid change (sserh)
I just did it on mine, the line you want to remove is going to be the top one. I believe that the one on the bottom is going to be the out line so it would be very difficult to flush the fluid from there. Make sure to have some needle nose pliers ready, the clip is really stubborn!
Top line is the one. I connected a clear plastic hose to it and flushed into a container stopping and refilling every 2 quarts until the fluid in the hose was clear . I believe half inch clear tube worked. I replaced the rubber o-ring and the clamp.
fluid is checked HOT with the engine running.
also...http://www.volvospeed.com/Repair/Transflush.htm
http://au.geocities.com/ozbric....html
