1 - 15 of 15 Posts
Today as I stopped to backup into my work parking spot as i was shifting into reverse the engine cutout until i stomped the gas pedal, a little sensitive all of a sudden.
If I'm lucky I get one S/S per trip, so if I waste it on one of yawls scenarios I'm bummed; rather ration my ONE S/S at a long light...and, as usual, Volvo appreciates your continued beta testing of S/S...
Start / Stop only enables if you are at a complete standstill. So what I'm guessing is you are reversing into a spot, where it requires a few second pause to change gears?
My stop start has shut off before I technically stop at a set of lights. Anyone else???
So i just picked up a T5 Momentum last week and noticed that once I shut off AS/S it stays off ... I mean for good ... it hasn't turned on all week.
Coming from an XC90, I know I had to disable it every time I started the car ... but on the XC60 once disabled it stays off for good even after restarts.
Is this normal or did I get lucky?
Maybe for MY2020 they changed this?
2021 Volvo XC60 Momentum T6
I have a 2019 XC60. There is an option for Start/Stop to have it on or off permanently thus not requiring to turn it off every time the vehicle is started. Just swipe right from the Home screen to see the option.
2019 XC60 Momentum here also. I thought it was on all the time in ECO mode and the switch controlled it in the other modes.
Yes, I am aware of where you turn it on/off ... but on XC90 this was something that turned back ON with every car restart ... hence needing to turn it OFF all the time. It was super annoying.
I am glad it stays OFF but doesn't sound like all of you are experiencing the same thing ... i have a 2019 btw.
My 2019 S60 T5 S/S can be turned off permanently in any mode except Eco of course.
I believe in ECO mode the start/stop is on but in the other modes it can be permanently turned off. I don't drive in ECO mode.
I notice it's extremely sensitive in Eco mode. It shut off almost before I'm at a complete stop. In comfort it waits a second after a complete stop to turn off and in performance mode, it doesn't shut off at all. Weird, but I've come to learn it's tendencies.
1 - 15 of 15 Posts
