I had to replace our 2014 XC60 R-Design’s battery this past weekend, and afterward noted that the driver’s side window down/up button no longer works in full auto up/down (when depressed through the full detent). I can still roll the window up and down, but I have to hold the button. The adjacent passenger side button (on the driver’s door) still works and has that functionality.
It seems awfully coincidental that this feature was disabled about the same time as the battery change. Any chance the battery swap shorted something out? Anyone else experience this?
Have you tried resetting the auto open feature per the owners manual?
According to my 2013 XC-60 owners manual:
Resetting
If the battery has been disconnected, the auto open function must be reset so that it will work properly.
1. Gently raise the front section of the button to close the window and hold it for one second.
2. Release the button briefly.
3. Raise the front section of the button again for one second.
If that process does not work, VIDA can recalibrate the window limits for auto open/close.
Question for you: Did you reset your BMS counter after changing your battery? P3 Volvos keep track of your battery health and the BMS system must be reset after a battery change.
You'll eventually start getting low battery warning messages in the DIM if you don't reset it. There is a DIY method using a combination of buttons (I've never had that work) or you can use VIDA.
Resetting
Wow. Interesting. It never crossed my mind that something like this would be a process or feature that could be “reset” or I would have checked the manual!
So no, I have not done that but given that this is a “thing” (LOL), I’m sure that’s the issue. I’ll follow these instructions. Thanks for pointing this out!
No, I have not. I’ll look that up and/or have the dealer reset next time I have it in. Thanks!
Update: that worked! Thanks all. Intuitively, this seemed more like an electrical or switch failure than a “feature” that needed to be reset. My apology for not just reading the manual!
For fun, give this process a shot:
I'm curious if it resets the BMS as they claim.
Reactions: AudiA4
