at start up the audio system works perfect. but that only lasts for about 2 min. then the speakers cut out. the head unit says it is playing and i can switch back and forth between all the functions, i tried resetting the audio levels to the factory settings. still nothing. turn ignition on and off and still no sound. only after a long period of time will the sound return, as if it re sets itself, but that only lasts for about two min then nothing. i'm thinking it has to do with the amp but unsure how to check it. Anyone had or having similar issues?
definitely sounds like a hardware component in the amp is bad. Heating up causing separation of a joint or something. before diving into that though, I would just simply check the connection on the wire harness to the amp under the seat.
Agreed on the amp. Someone could have kicked it or pulled a wire out with it being that exposed.
Try doing a full vehicle ECU reset.
Disconnect positive lead from the battery and short it to the body for 5 min.
Fixed my Info display / radio not functioning problems.
