Hey guys so I bit the bullet and bought these :
I was unsure of them but they are in fact really good!! Only way to get a uniform glow from led strips.
Basically you HAVE to split the lenses from the headlight, use a heat gun and a flat head screw driver I took apart one headlight in 7 minutes
(See MyNameIdeasWereTaken's video on seperating lenses)
I then screwed in the provided clips onto the black plastic frame piece. The plastic was tough so I first used a dremel to make a tiny incision then I screwed the provided screws in with some force. Be very careful with the dremel if you make your hole too big the screw won't hold. I made that mistake two times and had to use hot glue and super glue to be safe.
Plan out how you will arrange the tube first, then mark where you will mount the clips.
After that, snap the tube into the clips.
Wiring:
DO NOT wire these to the city or parking lights, when the car is running they will dim extremely low and will flicker. I think this is due to the PWM voltage.
I wired mine to a spare fuse with a switch in the interior
These are just as noticeable as my halos during the day I'll try to get some daytime shots.
Only flaw in my install:
I ran the wire like this since I was lazy and I don't care lol. You guys can probably do this more neatly.
Wiring:
