1 - 2 of 2 Posts
Hello, these days I particularly feel that my S40's transmission groans a lot when I put in the reverse gear. Especially in the morning, when I put the R gear (after starting my car and finishing warm-up), I hear something like spring popping under the leg room and feel the vibration or shock through the brake pedal.
Do you think there is something wrong with my car? Has anyone experienced a similar symptom? My car is only a little bit more than one-year-old so there should not be any problem in transmission. Do you think it might work better if I go to the service dept and check the transmission fluid? Thank you.
Always a good idea to check the trans fluid. I'll bet it's a motor mount gone bad based on the vibration you feel when you put it into reverse. Get the motor checked.
1 - 2 of 2 Posts
