1 - 10 of 10 Posts
The reason I ask is my 98 has a perfect, no rust sunroof but it has no rubber seal vissible around the top side like the S70 does. Is that normal?
Yes they are different. They're different part numbers.
Volvopartswebstore lists three for the coupe:
8614279
8626932
9152097
The first two are definitely C70 only whereas the last one is C70, V70, S70 according to Tasca's trademotion site. But looking at the roof I have in my coupe, the new barely used one I bought off a guy last year (that is going in when I replace the entire mechanism) and the one on my S70 - the two coupe ones don't have that metal band around the top that the S70 one has.
Good to know. Thank you sir.
another question. I noticed that my C70 doesnt have a pop up wind deflector when the sunroof is open like my 850's andS70s had. Is it missing or did the car not come with one?
Gary
Gary
This, I was wondering the same thing.
I wonder if a deflector fron an S70 can be installed?
There is much more wind noise from the sunroof (when open) in my C70 when my S70 has. Why wouldnt the C70 need it?
I have also the same question. My 2001 C70 does not have the deflector and the roof is very noisy, espesially when i open only the sunroof interior cover and the glass is closed. I have also noticed a small movement of the glass when i press it up with my hand which makes an annoying noice when the car hits a pothole:( . I used to think that the problem came when the previous owner changed the sunroof glass and probably something from the mechanism (may be the deflector) is missing.
1 - 10 of 10 Posts
