I took my XC70 in for an oil change, and a day or so later I tried turning on the approach lights with the key fob, and ... nothing.
Same with the backup key fob, and to double-confirm that it’s not a broken fob, the remote-start feature works (which requires pressing the lock button and then holding the approach light button down until the headlights flash).
The only thing I can think of that may have disabled it is that I was messing around trying to find the magic sequence for disabling the “service message,” and I wonder if I pressed some code that disabled the approach lights.
Any ideas? Anything I can check myself without taking it in for hundreds of dollars in authorized Volvo service fees?
Thanks in advance...
Discussion Starter · #2 ·
Problem solved!
I went into "My Car" and under lights, the approach light duration had been set to 0/off. Putting it back to 60s solved the problem. No idea how it got set to 0, but there it is.
Pretty common that it happens after a service that includes updates, even though iirc their instructions says to copy the old parameters and reapply them.
