Hey guys, I am working on replacing the AOC filter, pump, and oil for some preventative maintenance as it's been a good 6 years since it was done and I work that AOC pretty hard. The pinion nut is seriously stuck. It's not corroded or anything, I just think it may have been overtorqued by the indy mechanic that did this job 6 years ago. My HF impact gun can't get it off. Tried heating it up (not too hot though) that didn't help. I made a counterhold tool that uses two bolts threaded into two of the holes on the flange and really cranked on it with the breaker bar and I just bent the tool and the bolts.
In VIDA, they show 9995652 counterhold tool and 9997058 adapter to use as a counter hold. I found the adapter online but can't find the counterhold tool. Called around to some local dealers who were not helpful at all.
Trying to figure out how to proceed. I really don't NEED to do this right now but I already have everything apart and want to just finish up with it. Just wondering what you guys have used in the past as a counterhold or what other solutions you may have thought of?
The first impact socket I used kind of started rounding off the nut because it's such a shallow nut and the socket had kind of a deep chamfer. Found a better socket with a very short chamfer and it is grabbing fine and not slipping.
