1 - 12 of 12 Posts
I posted in the V60 forum about a fluid change on our XC , might want to have a look at if u haven't done it , it was in bad shape.
Did you also change the AOC filter?
Yep. I assume you pulled the pump out and cleaned the plastic screen?
What was your mileage? Did both my V/XC60 at around 60k and the xc was FAR worse.
Doesn't exist on P3 cars. Only a screen that picks up the clutch material.
Not true. Changed the filter on my XC60 and S80.
The new generation Haldex units do not have this filter. What year is your xc?
2011.5 on the XC and 2008 for the S80
I suppose I didn't ask what year OPs xc is. Take a look at screenshots below. Gen 5 does not have a filter. Your 11 XC has a Gen 4 which does have a filter.
100k miles....should have done it sooner. Diff and angle gear fluids still looked reasonable for the mileage though, but swapped out anyway with amsoil severe gear 75/90
I think 13 was the first year for the gen 5
Good call on the amsoil.
1 - 12 of 12 Posts
