1 - 8 of 8 Posts
Hi All,<p>Just got the car back form the dealer after they replaced the entire rear differntial/drivetrain.<p>I noticed on my report that they "removed AOC Clutch and cleaned, installed AOC Clutch with NEWPINAL Drive unit, replaced Final Drive"<p>I would greatly appreciate if someone could explain what these items are and it would be extra awesome if you could explain why they might have replaced/cleaned these items.<p>Thanks in advance!!
Re: AOC Clutch, Newpinal Drive Unit, Final Drive?? (so_calR)
AOC = Active On-demand Coupling, AKA your Haldex. <p>Final Drive = rear differential. <p>Not sure what a NEWPINAL drive unit is. <p>And why did you need your rear diff replaced? <p>As for the AOC cleaning, there is a TNN whereby the pressure / temp sensor can get fouled and cause you to lose your AWD function.
Re: AOC Clutch, Newpinal Drive Unit, Final Drive?? (Needsdecaf)
I had an oil leak at the back, most likely a seal, but the dealer told me it was an "internal leak" and they needed a whole new differential. My guess, they didn't quite know what to do so they installed a whole new one. <p>Here are my initial posts on the whole thing.<p>1.) when I first saw the leak: <A HREF="http://forums.swedespeed.com/zerothread?id=122015" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=122015</A><p>2.) after I took it in: <A HREF="http://forums.swedespeed.com/zerothread?id=122716" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=122716</A>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>so_calR</b> »</i></TD></TR><TR><TD CLASS="quote">I had an oil leak at the back, most likely a seal, but the dealer told me it was an "internal leak" and they needed a whole new differential. My guess, they didn't quite know what to do so they installed a whole new one. <p>Here are my initial posts on the whole thing.<p>1.) when I first saw the leak: <A HREF="http://forums.swedespeed.com/zerothread?id=122015" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=122015</A><p>2.) after I took it in: <A HREF="http://forums.swedespeed.com/zerothread?id=122716" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=122716</A></TD></TR></TABLE><p>OK, that was you. Can you scan the receipt with P/N's? That would help. <p>Hint, copy your receipt, take a sharpie to the sensitive spots, copy THAT and it's invisible.
Here's the receipt with the work done. Thanks for the help on this, SS is such a better resource than the dealer...I asked them when they were done what went on, why the clutch was removed (no one mentioned it was the Haladex) and all I got from them was a strict reading from the receipt about what was done...like I can't read or something...grrr<p>
LOL, didn't realize when I scanned at the high resolution it was going to be that big...oh well I guess no one will have an issue reading it <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0">
Re: (so_calR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>so_calR</b> »</i></TD></TR><TR><TD CLASS="quote">LOL, didn't realize when I scanned at the high resolution it was going to be that big...oh well I guess no one will have an issue reading it <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"></TD></TR></TABLE><p>That's why I use Photobucket....there's a max size, and it's easy to resize once posted. <p>Well, I had a hunch that "Newpinal Drive" was really supposed to read "New Final Drive" and after reading this I am quite certain that is the case. <p>The reason it reads the way that it does is that the Haldex (AOC / AOD / whatever) [Active On Demand Coupling or Active On Demand] is bolted to the rear differential – AKA the final drive. So what they are telling you they did was unbolted the whole unit, separated the Haldex, cleaned it, bolted up a new rear differential and put the unit back in. <p><br>
Thanks, now I finally understand a little bit of what they did, now I just want to know what an internal leak is...<p>Thanks again!!
1 - 8 of 8 Posts
