1 - 11 of 11 Posts
Hey guys, i dont own a R, unfortunately, but i figured you guys may be more likely to run 40's than everyone who owns a normal S60. I can get a real good deal on some Goodyear F1 D3 summer tires, but the website i was looking on doesnt have 235/45. Will riding on 40's make my car look weird and will it make my ride alot harsher? Just figured id ask if anyone had 45's then went to 40's and noticed if the ride got alot worse. Cause my ride is already pretty harsh, so i dont wana make it worse.
Re: (TGO)
Quote, originally posted by TGO »
what size wheel?
for my 18's i have 235/40, for my 17's i have 235/45
These are the standard tire sizes you're going to see on R's have a direct correlation to the size of the rim...
Width / Tire Wall - Rim Diameter
235/45-17
235/40-18
235/35-19
Some people are running 245 as well.
I'm running 235/40-18 Eagle F1 tires on my 18x8 Ultraleggeras, and still have rather slick 235/45-17 Pzeros on my 17x8 Pegs in the barn.
Re: (crimnlmnded)
i was thinking of putting the 235/40 on 17inch rims but i didnt know if that would make the stance very awkward or if the ride would be too rough
Re: (crimnlmnded)
Quote, originally posted by crimnlmnded »
I thought 235/40 was the normal size for 18's?
They don't have 235's in 35, I don't know about 45 though.
I thought the normal size for 18x8 rims was 245/40/18?
So most guys here run 235/40 on 18x8 rims?
Re: (vivek9856)
Quote, originally posted by vivek9856 »
yep 235/40/18 is the stock size, seems like a pretty small overall diameter tire for a car of such size. My S2000 had bigger tires than that lol.
Re: (swedeman)
Quote, originally posted by swedeman »
That it's the same sidewall height as the stock tires on 18's suggests it won't be too rough (yes, it's subjective, but if it really sucked, no one would ride on 18's or ever on 19's). It will probably look a little odd, given that the OD will be a fair amount smaller than normal (by almost an inch).
You'll also have the issue of inaccurate speedometer / odometer readings.
Re: (VTT5)
It likely would make your car look like it should be lowered (i.e., it's gonna look like it's been raised). As for the ride, you need to drive a vehicle with 40 series rubber before you pull the trigger. They're not for everyone, that's one thing you can count on.
Quote, originally posted by VTT5 »
...the OD will be a fair amount smaller than normal (by almost an inch).
Just how much can be calculated here: http://www.bimmerhaus.com/tech/gearcalc.xls
Re: Anyone running 235/40s? (swedeman)
Solely looking at tire diameter I guess it will look something like this,
Those are 18" Pegs but with 225/40-18 which is smaller in diameter compared to 235/40-18.
Re: (xman03)
Quote, originally posted by xman03 »
on 18's 45 would look way out of place imo. aside from aesthetics it would change the diameter of the wheel, affecting your speedo...though probably not much.
generally though, the bigger the rim the lower profile the tire. unless you want a 4x4
1 - 11 of 11 Posts
