Just seeing if anyone here knows if the Stock 18" Eudora BBS wheels will clear the brembo R calipers without spacers. If someone knows if they need spacers, 5mm or 10mm? IPD sale ends soon so I'd like to score some savings if possible.
Been there, done that. 10mm spacers required - which is an absolute minimum. Fronts with 10mm spacers clear the calipers by less than 0,5mm.
Thanks. That was the answer I was looking for.
To illustrate the point - this is with 10mm spacers:
That is a tight fit for sure. I guess when I go with the upgrade I will be sure to have some 10mm spacers. Thanks again.
