i went to a local called SPEED WORLD here in LONG ISLAND, NY, and the guy says that my cars radio cant hold an amp n sub... i think hes wrong. he said he has to replace the stock radio... but we all know that cant happen ... anyway, of anyone has thrown a sub and amp, let me know how to do it, my radio dock and some plastic covers are already removed so once i get some info, ill get down and dirtyyyy ill even take a pic of how it looks like and post it here..... THANKS!
volvo 4 life
Re: anyone know how to wire a sub woofer or amp to a 05 s40 (nme95k)
Quote, originally posted by nme95k »
Yea, hes wrong. I have had 5 different Sub/Amp set ups in my car ranging from an Infinity Basslink (my favorite) to a 15" Orion P-Series... all of which WORKED!!! Lol!
You dont need to mess with the factory head unit at all, so start putting that back together!
You will need an Auxiliary audio input adapter (look on eBay for one). You will tap those wires inline with your rear speaker to draw a bass frequency. Then run your RCAs to that which will plug into your amp.
Run your power wire (driver side I think). And ground your ground wire somewhere safe. The remote wire you can plug into a fuse that turns off when the car is off and on when the car is on, for example the ignition fuse... (use one thats in your glove box).
I personally had my remote wire on a 2-way on/off switch, so when I wanted the bass I turned it on and when cops were close by I turned it off. GA noise pollution laws are lame...
Hope this helps a little.
Re: anyone know how to wire a sub woofer or amp to a 05 s40 (Kallvin22)
No, not like that...
Note, the description says: "Operates on ALL Pioneer Radios with CD changer port commonly known as IP-Bus."
You can go to your local car audio shop, heck maybe even Best Buy and get a universal one. But here is a link to one that will work!
Its actually called a Line Output Converter:
http://www.12volt-travel.com/l...513ab
http://********************/smile/emthup.gif http://********************/smile/emthup.gif
Re: anyone know how to wire a sub woofer or amp to a 05 s40 (s40boy)
Some additional info or installation pics would be greatly appreciated. http://********************/smile/emthup.gif
