Discussion Starter #1
I tried to go through the wheel well with no luck. I can al,ost get to it going through the top, ut the washer fluid tank blocks it.
At this point I am not sure what to take apart in order to get at it.
Undo the screw holding the filler neck of the tank, then pull and twist it. It will come out and give you a little more space. That side is difficult.
Discussion Starter #3
Thanks. I gt lucky on a goggle search as well. Had I all stepped out with drawings.
