1 - 20 of 27 Posts
· Registered
EST Projectors w HID installed in MY 2005 XC70
The title says it all-- Has anyone installed the EST projectors w HID kit in an 05 XC70?
If yes, please post install or direct me to an install thread. Specific areas of interest are:
1. The wiring within the EST Headlight,
2. Wiring the HID plug and Ballast,
3. High Beam bulb choice,
4. How the EST cable is connected to the OEM headlighgt harness and
5. How all of that is connected to the XC70.
Any other installl help will be appreciated.
TIA :)
oz
· Registered
01-04 plugs the same
05+ are different plugs
I am kinda curious to see the plug mount on the back of the headlight ...
· Registered
Discussion Starter · #5 · (Edited)
Answer to #1: Pic of back of EST Projector with HID cover open
With this setup plugged into the car, the LED's were lit on all 3 headlight settings. The high beam was never lit. The HID bulb only flickered at the 12 oclock setting on the headlight switch.
Ask #2: The OEM headlight was not HID
· Registered
didnt you use to drop 05+ headlights in your XC70s and your old Silver V70?
Yes but you had to cut up the harness for the 05 Headlights to work .
It looks like the EST headlights have a custom harness to do that now.
Ozzie -
Did you try stock bulbs and to see if those work ?
· Registered
I had stock high beam and parking/turn signal bulbs...the parking /turn signal did npt work. The high beams were barely glowing..
I am checking continuity on everything this weekend and will post results. Wiring diagram for the OEM plug in teh car that the OEM headlight harness connects to whould be appreciated.
David
· Registered
Discussion Starter · #13 · (Edited)
One at a time, I hooked each element of the headlight (dipped HID, High beam, parking lights and then LEDs) directly to the battery -- EVERYTHING worked. Pulled the bumper and installed the new headlights,
REsults
1. High beams work
2. HIDs flash once and go off when key is turned to position II. After starting engine, Low beam failure error message come on and HIDs not working.
3. Parking lights do not work,
4. Turn signals and 4 way flashers work
5. LEDS were NOT connected BUT THEY ARE WORKING !
Power to High beam is from OEM Connectiors 54/23 (left light) and 54/22 right side) pin # 7. HID power thru pin # 3. Same as Volvo Wiring diagram for both HID and high beams.
Parking Turn Signals thru pin # 9 instead of pins 5 & 1 on the Volvo diagram (may explain why parking lights not working). Everything is grounded to pin #10 per Volvo wiring diagram. i have no clue how to get pins 1 & 5 connected to the parking lights instead of pin # 9
Plugged and unplugged the HIDs while engine was on.....they still did not work. Increasing headlight fuse from 20 AMP to 30 AMP also had no effect on the HIDs. Waited until dark and restarted the car..NO Change HIDs and front parking lights are not working
Any ideas??
· Registered
Discussion Starter · #14 · (Edited)
EST Projectors w HIDs in an 05
Got it done. Also painted the eggcrate grill flat black. It is better color match in reality than in the photo: Grill to Forever Black on bumper cover :D Thanks again for the wiring diagrams link. This was not a "plug and play" mod.. :eek:
· Registered
Great job Ozzie, I think the chrome versions do a better job of hiding the Audi DRL. i would be interested in seeing a set of these pulled apart, Amber reflector deleted, and spray a matter silver (similar to the R bezels. though i think by that point you are better of with a set of Retrofitted projectors.
· Registered
Discussion Starter · #16 · (Edited)
Thanks. The job was a PIA. I still need to put Klasse wax on the grill. I am waiting a couple more days for the paint to cure. I think that will bring the grill and bumoper colors closer together.
The matte silver does look nice. I happen to like the LEDs and will be putting a swtch in to turn off the HIDs, leaving the LEDs as DRLs. The way the HIDs are now wired, the center position on the headlight switch does not turn off the HIDs. The LED wiring is a mystery (internal within the headlight housing and are powereed-up when the HIDs are on). If that was not the case, the peanut bulb wiring may have been a possible source to power the LEDs. As it now stands, the HIDs and LEDs are on all the time.
The other fun factor is that the HIDs doen't always power up on the first start...another mystery.
· Registered
Does it flicker and not turn on? it could be a failing ballast if its not coming on all the time.
· Registered
I am thinking its more of a power issue , that the car doesnt see the correct power draw and then doesnt supply power to the headlights .
The newer S40 have the same issue , talk to TheShadow about this .
· Registered
Discussion Starter · #19 ·
Flickering was intially the problem. Power to the HIDs was increaed by adding the bi-zenon circuit to the old halogen ciruit that was powering the HIDs. This powered up the HIDs. They draw just over 17 amps.
Now the HIDs will both turn on at Key Positin II but on engine start, the left HID and sometimes both HIDs go off. By repeating the engine start cycle, 1 , 2 or 3 times, tboth HIDs stay on.
Hopefully that makes sense.
· Registered
yeah I had the same issue after awhile it went away.
1 - 20 of 27 Posts
