I did a bunch of stuff on our wagons today, and the last thing I went to do was swap out the fuel filters. I'd seen how easy this was, and was anxious to knock em both out. On both cars, I was able to get the quick-connect off on the in-port…but on both cars, the clip on the out-port was stuck. I monkeyed with it on my car for 20 minutes before hooking the in-port back up and moving on to my wife's car…only to find the same thing with hers! I didn't want to risk breaking them (looks like it's not an easily sourced part), so I thought I'd check and see if anyone has a trick? Would something like PB Blaster help with something like this?
So it finally just came off? I can barely squeeze the clips. I think I'll hit it with PB blaster, let it sit, and hope for the best.
It can be hard to fully depress the tabs after crap has built up. You could try using a flathead or pliers, or maybe you can find the proper tool somewhere?
That looks like a pretty slick little tool. I may try to glue some little "nubbins" to a pair of needle nose pliers to see if I can't fake the funk. I also didn't realize that you squeeze the front of that tab to unlock and the back to relock. Perhaps consciously focusing my efforts on the front will make a difference too. Thanks!
