Re: (tpezzolo)
Quote, originally posted by tpezzolo » |
Any advice about dropping the headliner or running the wires? I will be doing one of these installs in the very near future. Can I send you an email if any questions come up during my install?
Sure. You can email me. I'll provide whatever info I can remember. I always intend to take pics during installs, but never actually do it.
As for dropping the headliner, my advice is to not try to shortcut it. There were many times I stopped pulling trim and tried to squeeze my arm up there, only to waste 20 minutes pointlessly fumbling for wires, etc. You will need to pull all pillars, grab handles, visors, and moonroof trim. Run all your wires, cut your hole, mount your plate, etc. Then put it all back, connec the player to the wires, and screw it in place. I'm sure for experienced folks, this is all relatively painless.
And, as stated above, route your wires so they don't interfered with the airbags. I tucked mine behind the bag brackets, then came across at the crossmember behind the moonroof. Power wires I brought up on the driver's side from the fuse panel, and audio I did on the passenger side from the glovebox where I mounted the Gateway aux input. I have no idea about wires already being up there. I certainly didn't find any.
