1 - 10 of 10 Posts
I was getting occasional P0420 (cat failure) but now the CEL with that code stays on all the time. I've had the EST downpipe and exhaust for about 2-3 years without issue and my '06 V70R has 118K miles. No other codes associated with the P0420, no visible smoke, normal oil burn and recent tune up (filters, plugs, oil.) Thanks!
Maybe you need a oxygen sensor spacer (like a "CEL Boss"). My TME DP ran fine without a spacer for about 2 years, then I starting getting the "low efficiency" CEL. I put the spacer on and no more CEL.
Truth be told, a high-flo cat simply just doesn't have the longevity of a stock cat. Do yourself a favor and buy a "CEL BOSS" and it will get rid of the code within 100 miles.
I put a High-Flo Magnaflow in last october and as of early April I could shoot flames. Worthless products that die just as quickly as they are put in...so leave it in, hollowed out, to appear as if it is functional, and call it a day.
Edit: Nevermind, thinking of something else.
I vote for a spacer as well your cad has probably been eaten away a bit and the o2 sensor is sensing it is not working.
+1 for no cat...more vroom vroom
Any suggestion where I can get the right spacer? What about replacing just the cat? I can't recall if it's held on by clamps or welded. I've seen 3" replacements for around $100.
My tune I think has fixed my fireball shooting abilities :/
Ipd sells a spacer I believe or your local auto store might
Get a 90 degree spacer for 034 motosport...or motorsport ...something like that...I have one and its sweeeet looking and needs very little clearance...and I think the newest EST Dp's have a removable cat like that..not 100% though
1 - 10 of 10 Posts
