1 - 20 of 40 Posts
Any guidance on the following codes thrown? (car now goes into limp mode) ** updated
Thanks for help.<p>CEM - Central Electronic Module (Master ECU)<br>--CEM-1D04 ECM software. Faulty Signal. Intermittant fault<br>ECM - ENgine Control Module<br>--ECM-531D Control module internal fault<br>--ECM-91B7 Throttle position (TP). Faulty position<br>--ECM-903C Reconfiguration emission system. Information<br>--ECM-9150 Throttle position (TP) sensor 1 Faulty signal<br>--ECM-913C Throttle Unit. Faulty signal<br>--ECM-919A Engine control module (ECM). Faulty signal<br>--ECM-9160 Throttle position (TP) sensor 2 Faulty signal<BR><BR>
<i>Modified by iamnotmad at 7:18 PM 7-27-2009</i>
Discussion Starter · #2 ·
Re: Any guidance on the following codes thrown? (iamnotmad)
oh, also, if no info on the specific codes above, how bad is it to drive in limp mode for a few days until I can get it to the shop (with the CE light on)?
Limp mode shouldn't hurt anything. As long as your CEL doesn't start flashing.<p>If it were me i'd suspect the throttle position sensor. I'd start by getting a diagram of that circuit as well as specs.<p>
Re: (iamnotmad)
Oh Boy now when i start the car it revs up and down as if I were pressing the gas pedal then letting off over and over. And actually pressing the pedal does not seem to do anything. Guess this means i have to get it towed to the shop. What a bummer. <p>Any other suggestions? <p><br>Thanks.
Re: (iamnotmad)
Yup, sounds like the throttle position sensor. <p>In reality the car has no "throttle". It's a drive by wire and even that is a bit misleading. The car reads the throttle position as a "torque request" then calculates what boost and throttle butterfly opening (and all the rest) is needed to generate, and adjusts accordingly. <p>There is no 1:1 relationship between the pedal and the throttle.
Re: (Needsdecaf)
where is the throttle position sensor? Is it difficult to replace? Might be worth a try for me, considering otherwise I will have to tow to the shop. oy!<p><i>Modified by iamnotmad at 9:03 PM 7-9-2009</i><BR><BR>
<i>Modified by iamnotmad at 4:03 PM 8-3-2009</i>
Re: (iamnotmad)
TPS is part of the throttle unit and I don't believe its replaceable separately. Luckily you can replace the throttle on these and not need new software but still need VIDA to command calibration.
Re: (Oceans60R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Oceans60R</b> »</i></TD></TR><TR><TD CLASS="quote">TPS is part of the throttle unit and I don't believe its replaceable separately. Luckily you can replace the throttle on these and not need new software but still need VIDA to command calibration.</TD></TR></TABLE><p> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <p>This happened to me last year. You have to change the throttle body. Runs about $300 for the unit IIRC.
Re: (IwantaS60R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>IwantaS60R</b> »</i></TD></TR><TR><TD CLASS="quote"><p> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <p>This happened to me last year. You have to change the throttle body. Runs about $300 for the unit IIRC.</TD></TR></TABLE><p>oh man thats not what I wanted to hear (read). Ugh.
Re: (IwantaS60R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>IwantaS60R</b> »</i></TD></TR><TR><TD CLASS="quote"><p> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <p>This happened to me last year. You have to change the throttle body. Runs about $300 for the unit IIRC.</TD></TR></TABLE><p>What about VCNAs supposed 200K mile warranty on the electronic TBs?<br>Or is that specific to certain model years, 99-'03, I believe?
I probably joined a bit too late and hopefully you have your issues resolved but......... there seems to be a lot of codes thrown at the same time. Any prior history before this? Any recent work done or mods?<br>
Discussion Starter · #13 ·
Re: Any guidance on the following codes thrown? (Denis)
Update:<p><br>The car is acting very normal now. I drove it a tiny bit just in the alleys behind my house. <p>Any chance this was a flukey thing? And this issue could be gone at least for a while? It seems like something should still be wrong. I guess I'll find out when I take it out today.<p>Oh, Denis, only recent service was spring seat replacement.<br><BR><BR>
<i>Modified by iamnotmad at 4:05 PM 8-3-2009</i>
Discussion Starter · #14 ·
ok, so the CEL came back on yesterday, and it's back in limp mode. Unfortunately my local shop suggested I take it to the dealer after I told him what was happening. So I guess I need to prepare for inflated repair costs. <p>I guess the throttle body (if that is what the prob is) is not under any kind of warranty outside the 4yr?<br><BR><BR>
<i>Modified by iamnotmad at 4:06 PM 8-3-2009</i>
Discussion Starter · #15 ·
Ok, so dealer says, after lots of time tracing the problem, it is the Electronic throttle actuator, which I guess is synonymous with electronic throttle module and electronic throttle body. Bottom line, with all of their time spent researching the problem $970. He took an hour of research time off, and I have a 15% off coupon, so it'll be around $825. Ugh. U guess it could have been worse. <p><br>I guess that semi-recall a while ago was pre-2004 models right (was it only up to 2000?)<p>
Re: (Needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote">Yup, sounds like the throttle position sensor. <p>In reality the car has no "throttle". It's a drive by wire and even that is a bit misleading. The car reads the throttle position as a "torque request" </TD></TR></TABLE><p>I'd, ummm, like to request some torque please? When you have a chance?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>iamnotmad</b> »</i></TD></TR><TR><TD CLASS="quote">Ok, so dealer says, after lots of time tracing the problem, it is the Electronic throttle actuator, which I guess is synonymous with electronic throttle module and electronic throttle body. Bottom line, with all of their time spent researching the problem $970. He took an hour of research time off, and I have a 15% off coupon, so it'll be around $825. Ugh. U guess it could have been worse. <p><br>I guess that semi-recall a while ago was pre-2004 models right (was it only up to 2000?)<p></TD></TR></TABLE><p>Wow, you're getting hosed. Sorry. <p>As for a throttle recall. There was one for 99-01 and some 02's and it was for software only. There is an extended warranty in place for those same vehicles that covers the ETM or Electronic Throttle Module for 12 years/200K miles<p>Our cars do have a throttle which is as Joe said, Drive by Wire. <p>You could contact John at Boston Volvo and find out what the actual price is for the throttle. The programming involved DOES NOT require any software, just a calibration using VIDA. Takes about two minutes and that includes logging into VIDA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>iamnotmad</b> »</i></TD></TR><TR><TD CLASS="quote">Ok, so dealer says, after lots of time tracing the problem, it is the Electronic throttle actuator, which I guess is synonymous with electronic throttle module and electronic throttle body. Bottom line, with all of their time spent researching the problem $970. He took an hour of research time off, and I have a 15% off coupon, so it'll be around $825. Ugh. U guess it could have been worse. <p><br>I guess that semi-recall a while ago was pre-2004 models right (was it only up to 2000?)<p></TD></TR></TABLE><p>Should run about $700 not $970.
Re: Any guidance on the following codes thrown? (Oceans60R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Oceans60R</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Wow, you're getting hosed. Sorry. <p>As for a throttle recall. There was one for 99-01 and some 02's and it was for software only. There is an extended warranty in place for those same vehicles that covers the ETM or Electronic Throttle Module for 12 years/200K miles<p>Our cars do have a throttle which is as Joe said, Drive by Wire. <p>You could contact John at Boston Volvo and find out what the actual price is for the throttle. The programming involved DOES NOT require any software, just a calibration using VIDA. Takes about two minutes and that includes logging into VIDA. </TD></TR></TABLE><p>Haven't checked BV but myswedishparts has it for $380
Discussion Starter · #20 ·
Re: Any guidance on the following codes thrown? (IwantaS60R)
Yeah, I know it's cheaper to order elsewhere, but there was not much I could do, and they knew it (the car was not really drivable). I'm sure they tacked on extra bs "research" time. Especially since I had a 15% off coupon. Ultimately, I paid $825 after my 15%. Still about $125 over what it should be I guess.<p>Without any actual evidence of how much it should cost (from a dealer) there's nothing I can do. Even with that they can just claim "research" time. <p>They did do an oil change for $30, that's about $20-$25 less than normal.<p>
1 - 20 of 40 Posts
