Hey guys. Finally trying to diagnose the occasional Anti Skid service required message. I have the following codes. These codes were pulled a while ago so i should probably have them pulled again. Car is a 2005 S60 T5.
BCM-0121 Yaw rate sensor signal outside its permitted range
BCM-0130 Brake pressure sensor 1 Signal too low
BCM-0133 Brake pressure sensor 2 Signal too low
BCM-0136 Brake pressure sensors 1& 2 signal outside its permitted range.
The message seems to stop popping up when its cold out so not sure if that helps.
Thanks.
Using VIDA I have successfully recalibrated brake pressure sensors and the error went away. The Yaw sensor fault may be a faulty yaw sensor as I have seen that before.
Unplug the battery and have the car realigned, make sure the steering is dead on straight, then drive for a while and it should go away. Having a bad steering wheel alignment can piss the sensor off.
