Lift with big tires....my dream daily...literally
Nice. Trying to get my brother to cut some out on a water jet, but he's lagging. Mainly, for the rear subframe as I have a different trick for the front end.https://lensdump.com/i/8zOVxc
I was able to test a side by side... I have more clearance than an xc90, and almost as tall now. If I had sub frame spacers, I would be.
Sent from my LG-H918 using Tapatalk
I've got a laser at my disposal. Let me know.Nice. Trying to get my brother to cut some out on a water jet, but he's lagging. Mainly, for the rear subframe as I have a different trick for the front end.
Sent from my ZTE B2017G using Tapatalk
I've got a few things I'm working on.Are those xc90 LCAs? Badsweede lift springs... Nice.
To use the XC90 LCAs you'll need the rest of the XC90 front end. That's spindle/hub, ball joints, calipers and rotors, and axles. XC70 Struts should swap over. There is a slight modification needed to fit everything and then there's making sure everything can be aligned. I have most of the parts assembled, just waiting on my brother to come up with the rear spacers and I need a driver's side XC90 axle before I can test everything.I look forward to your write up, if those are xc90 LCA and your doing what I think your doing....
I'll be putting those on my ToDo List with axle swap, awd upgrades and spacers.
Is this yours? Got any build links? I'm totally down for this.Lift higher!
Nope, not mine. Here's the link: https://www.drive2.ru/r/volvo/468150061948207552/ (auto-translated https://www.drive2.com/r/volvo/468150061948207552/)Is this yours? Got any build links? I'm totally down for this.
Wow! looks like an Xterra.Lift higher!
