Nice!
It should be pre-wired. Even my NA had it.Question, in didn't pull out the whole length of the two wire connector going to the amp, I just cut the longest length I could with the intention of running my own wire (too much work, not enough time to get it out, and the driver's door wouldn't open). Is this two wire connector already pre-wired in the vehicle for the amp? If not, anyone know where the other end terminates.
Thanks!
Sent from my ZTE B2017G using Tapatalk
If the car didn't have a centre channel and upgraded stereo it may need dealer intervention.Sweet! Thanks guys!
Could be. I'll be going there tomorrow. Did you happen to see if the headlight were HID. My XC started winking randomly at people .I've read that if the the HU came from the same MY than it's possibly a direct swap... We'll see. If it doesn't work, I still got an amp and I'll sell the HU
I may go back and pick the speakers out of it next time I'm around, I really just ran out of time to mess around with it.
Hahaha! They are halogen and only one.Could be. I'll be going there tomorrow. Did you happen to see if the headlight were HID. My XC started winking randomly at people .
Now that I know I'll remove all the speakers and. Sell them to you for $1,000,000.00 !
Most likely first thing am. I'm on my own in the am.Hahaha! They are halogen and only one.
Ahhh you bastard! Good luck opening the drivers door! Most of the engine bits are stripped and the interior is a mess.
I may be in the Hammer tomorrow and may go back to check it out. What time are you going? Shoot me a PM.
DIAGNOSTICS>FAULT TRACE>DELIVERYHow do you clear the codes with Vida?
Is there an option within those tabs displayed?
Yeah, why couldn't it be easy and just be the PS pump? And why can't the AC compressor just come out the bottom? We should have a TV show on "P2 Mysteries"Also, getting a whine on cold starts or warm starts after sitting for 30mins. Haven't had the time to dig into this as it is gross outside, but it sounds like it coming from under the vehicle somewhere around the passengers' side fog light/oil filter/accessory belt area. I can't really hear it from inside the engine bay and the sound doesn't change with RPM or with turning the wheel. The noise doesn't start immediately, kind of like ~30secs after start then goes away once fully warm. Sometimes the radiator fan will come on when cold. I'm leaning towards something with the AC system.
Thanks. VIDA isn't that intuitive lolDIAGNOSTICS>FAULT TRACE>DELIVERY
Scroll to bottom and there are options:
ERASE ALL, READ ALL, ERASE (selected module).
