hi!
are you talking about the H7 headlight bulbs? if so, Daniel Stern and some others have offered a more high-efficiency H7 bulb that draws the same power, but allegedly sheds more lumens,... i haven't tried them yet myself, but find the idea interesting; just not to the tune of over $20-something/ea until i know more about them.
cheers!
e
One of the sad things about the aftermarket parts market is that nobody actually tests their claims, and headlights are a particularly bad area.
There are many aftermarket bulbs which claim improved performance, but actually DECREASE amount of available light. Not all bulbs are the same, there are some that are better than others, but seldom it will justify the cost. Stock headlights, on the other hand, must meet certain standards with that particular car.
One thing I think is particularly funny is the way that kids nowadays lower their cars and install all the aftermarket lights. But you usually have MUCH better light performance simply by just getting a headlight alignment after you change the geometry.
I agree with u joeflies that there are bulbs out there that just simply, are just for show and they luminate the road worse then what you started with in stock. The reason why I brought up this question, and it does not relate only to the headlight H7 bulb is that I was thinking of changing the stock ones. I'm just trying to figure if there is a remote possibility of getting true Xenon for the S40. If not, I guess a set of PIAA's would be the next best thing although they cost around $100 a set.
Ray
hi joe!
while i would have to agree with you on some counts, i can't aggree with you on all of them.
first, many companies *do* test thier lights; the problem is that there isn't one good impartial standard by which to do this, and it's hard to find the details of how exactly tests were done to know if they're comparable.
that said, that's why i'm not jumping at the "high effieciency" H7s that Sterns offereing; i have to see them first, or feel better about putting down the bucks to gamble!
secondly, much as we'd like to believe otherwise, the standards here in the US that lights must adhere to have been outdated for decades, and are in (controversial) review once again as we speak; most EU countries have significanty better standards (and testing) for lights, hence Eurocode lights are generally better quality in terms of light output and beam pattern dispersal. anyone who's swapped out the stock trash headlights that come in most american autos for a good set of H4 lamps will know this to be true. those lamps easily justify their cost in terms of reduced eye strain, and generally improved visibilty, leading to improved driver safety.
thirdly, i'd have to aggree that there is much bogus trash on the lighting market these days that relies purely on marketing and misinformation. many of the bulbs we see kids using now actually have coatings on them to color the light, allegedly to give the impression of HID lamps, actually reducing their overall output! (however studies are showing that the human eye is better at picking up detail from light that is more yellow in spectrum than blue, casting doubt on whether the HID lamps are really more effective. the initial impression is that bluer light is brighter, and that the HIDs are putting out "more light" leading one to believe that there may actually be more light available, when this simply isn't true.)
lastly, i'd have to agree with you that many vehicles would benefit from a headlight alignment after suspension modifications. in fact, some EU countries actually require headlight aiming adjusters to compensate for variances as slight as passengers and load.
cheers!
e
quote:
Ernest,
the latest (and best) HID lights do not emmit "bluish" light. They emmit a light that is as white as daytime light. From certain angles you may think they are bluish but that is because of the angle. You are seeing one of the colors of the white light which is blue! From certain other angles you may see yellow or even pink!
Yannis
quote:
Originally posted by GrecianVolvo:
Ernest,
Yannis
hi yannis!
i'm aware of the fact that HIDs have evolved somewhat, but the fact that they still can't put out an evenly dispersed evenly colored light means that they're still substandard in my book.
i understand that HIDs have the advantage of using somewhat less power to make their light, and that's an advantage to the designers that are looking to get as much efficiency as possible from everything. they also still look a little different, and Marketing loves anything they can push off as "New and Improved", and charge more for. ("Now how much would you pay?")
until they can get an evenly colored beam across the entire dispersion area, they've still got a way to go. for now, they're certainly not something i'm going to be willing to pay extra for, and would happily prefer a good quality Quartz-Halogen!
cheers!
e
