There is a somewhat annoying rattle that seems to be coming from the DS a-pillar or that corner of the dashboard. I've tried to trace it, but have been unsuccessful. Is there anything in these cars that typically makes such a noise? Any shortcut that someone can offer would be great.<p>Thanks!
Re: annoying rattle (855turbo95)
The only thing I can think of are loose or missing screws that attach the dash cover. Pop the side vents out and check the screws. There are two (I believe) under the side window defroster vent and one underneath the side dash vent. I remember having a small rattle that I could never chase down. I replaced my dash cover and after putting it back together the rattle was gone. My guess is I had a loose screw (no comments please) that was causing part of the dash cover to vibrate. Hope this helps.
i agree with with the guy above...probably a loose dash cover. if your dash itself is loose it may be one of the bolts that secures the dash itself which is under the cowl area.
