I took the angle gear apart and have chipped teeth on the ring and pinion gears. I just need to replace those parts if possible. From all my searching I can find a whole new angle gear assembly, but not the gears separately. Has anyone successfully sourced these parts?
The ring gear is pressed n glued to carrier so they claim no field serviceability. Thus no parts offered.
2005 V70R, Midnight Blue, M66
Your best bet is going to be a junk yard. Same AG used across several models. Looking at $500 to $800.
How did the gears get chipped? They are in constant mesh. What is the wear pattern on the faces of the good teeth?
