1 - 20 of 23 Posts
I have a 2017 Volvo XC90, built in late 2016. I would like Android Auto integration, Volvo sell the following kit for a console that has only one USB Port:
https://accessories.volvocars.com/InstallationInstruction/Document/VCC-506407-7/en-us/XC90(16-)/2017
My dealer quoted me about $750 to install, the kit itself is about 175. Has anyone here been brave enough to install this themselves, then have a Dealership load the software? I am mechanically savvy and somewhat savvy with wiring. I would like to save the 3 hours labor that is quoted for this.
Look here: https://forums.swedespeed.com/showthread.php?536514-Retrofit-MY2016-to-Have-2-USB-Ports
you can find part numbers for USB module and cover. This is all you need before going to dealer for software load.
I did it as well, just replaced USB module and cover. No new wiring that being added later.
Here is the thing. The instructions are all you need. My sense is that you want to know if there are short cuts or things to be concerned with. That tells me that you do not have a lot of experience in doing these types of modifications. I have over the years probably done 25 to 30 different cars adding everything from navigations systems to stereo systems to aftermarket electrical/electronic components. And I am still very careful as it is easy to screw things up. It is very easy to scratch plastic or break tabs that require the purchase of new components. You need to follow the instructions carefully and not skip anything. Volvo provides very concise information as to what is required. They have an expectation that the person doing the work has prior assembly disassembly expertise. It is time consuming otherwise it would not cost $575 for labor ($750-$175 parts). That equates to about 4 hours. My guess is that someone who has done it before will take only about 2 1/2 hours. If I did it for the first time I suspect it would take me around 5 or 6 hours as I am leaning as I do the job. Once it has been done you can try and figure out ways of doing things differently. But that only comes after you have done it a couple of times. From what I can see it is not a difficult job, just a time consuming job. What I have learned over the years: get yourself some tight fitting white gloves (cotton). Buy yourself some plastic prying tools so that you do not scratch things up. Get yourself some good quality screwdrivers of various lengths and sizes. You will also need various wrenches and/or sockets. Read the instructions several times from beginning to end to insure you understand visually what is happening. Don't skip steps. Don't do things out of sequence. Be careful when using force. Once you break a plastic tab it is toast generally. If you only do the partial you will probably not come back and finish it. Set aside 1 1/2 times the estimated time required. Take your time. If you have never done this type of stuff then I would not pursue, but have the dealer do it. As an example I added the trailer module and the wire harness on my car. I followed the instruction precisely. Even with the pictures they provide it is not often enough if you are doing the task for the very first time.
It's actually a free install your dealer probably just isn't aware.
Model year 2016 XC90s were built with a single USB port which is not capable of supporting Android Auto functionality. Should a customer request to have this functionality added to their car, it can be added at no cost to them by following the instructions under Service.
https://static.nhtsa.gov/odi/tsbs/2019/MC-10165238-9999.pdf
Originally posted in this thread by KentXRS https://forums.swedespeed.com/showthread.php?389009-No-android-auto-for-2016-XC90/page12
To be more specific, it only covers 2016 XC90 with Chassis rang: 0000000-0095354. Check the last six digit numbers of the VIN, it's the car's chassis number.
Had me worried for moment as mine is at the dealer now and this on the list. My chassis # is 045423 so I am good :D
I wish it were that simple. It is a little more comprehensive for the 2017 model year. https://accessories.volvocars.com/InstallationInstruction/Document/VCC-506407-7/en-us/XC90(16-)/2017
I used for my ex-XC90 MY16 this manual:
https://accessories.volvocars.com/InstallationInstruction/Document/VCC-506407-1/en-no/XC90%2816-%29/2018
And just replaced USB module and cover. Its immediately showed that now I have USB1 and USB2 port, when I choose USB stick with music.
New instruction adding some wiring and fuse. But in case you are not going to plug any other USB device that is not USB stick/drive it should be fine. and I had no claims from dealer when they installed software after.
So you only had one plug, not the two plugs (one behind a block off plate)? From this you were able to get Android Auto to work?
AA was not installed from factory for my car, so it had single USB port.
Later when I asked dealer what is required to get AA, they said 2 USB ports and software required.
Found topic here in forum about it, replaced module by myself, got appointment with dealer, and they loaded it without any issues.
But, even before loading AA to car, I was able to use both USB ports having 2 USB sticks with music plugged.
Discussion Starter · #13 · (Edited)
I see what you are saying, sorry I confused myself, the top plug was for a 3.5mm audio cable.
So you ordered 32204228, and then pulled the usb plate, disconnected, got new plate with the Dual USB module and then plugged into the back of that. Is this correct? Did you order from Volvo dealership or one of the online Volvo parts places? (tascaparts, volvooempartsdirect, etc.) This info is highly motivating!
I am still confused that for my Model year Volvo is suggesting that I re-wire the factory plug starting at Step 25
https://accessories.volvocars.com/I...06407-7/en-us/XC90(16-)/2017/T6 AWD/Automatic
So one of these is for Smart Phone Integration which includes certain android phones and the other one is for Car Play. They both have the same install instructions and also include the same software upgrade. So not sure why there are two?
Car Play Application
[SUP]4 [/SUP]
Application[SUP]4[/SUP]
31466842
The following two articles are recommended for iPhone 8 and onwards for the strongest possible signal reception.
Installation kit, for vehicles without double USB port in the center armrest
Application, for vehicles without double USB port in the center armrest
32204602
[TD="class: product"]Part. No.[/TD]
[TD="class: product"][/TD]
Application, Smartphone integration[SUP]2[/SUP][SUP]3[/SUP]
31659192
+ Installation kit, for vehicles without double USB port in the center armrest
+ Application, for vehicles without double USB port in the center armrest²
32204602
I have ordered these parts, from local shop (non-dealer):
-USB hub (31407038)
-plastic panel (31377892)
I had on my car USB module with AUX port (3,5mm audio) and single USB port. (like shown on step 20 from instruction of your post)
new module and cover has AUX port and 2 USB ports. (like shown on step 48)
I just re-plugged existing 2 wires shown on step 31 and this is it.
Step 25 wiring looks if you have USB only, and no AUX. So this additional wire for AUX.
so in case you have already in car AUX and single USB port, you can follow above.
In case you have no AUX, like shown on step 22, its better to go to dealer for new wiring.
Discussion Starter · #16 ·
-USB hub (31407038)
Hey Kent quick question for you. The instruction you sent show different part numbers than the ones that you ordered.
https://accessories.volvocars.com/InstallationInstruction/Document/VCC-506407-1/en-no/XC90(16-)/2018
The link lists 32204228, 32207897
But you ordered 31407038, 31377892
Why the deviation, what led you to order different part numbers?
Hey, I ordered part numbers that I found on this forum and also I checked the parts on web-site of Volvo if its OK for my car model year.
here https://usparts.volvocars.com/a/Volvo_2017_XC90-20l-4-cylinder-Turbo/_51513_7495894/Usb/GR-448730.html
You can check MY year of your car there on section Electrical System > USB
Discussion Starter · #18 ·
Kent or DrManny do know how much you paid to get the application installed? I called to get a quote they said 21.42 for the software, then 150 to install. What in the hell?
Discussion Starter · #19 ·
Anyone have any thoughts about loading this software themselves somehow? I am not familiar with how the whole Vida process works.
How did you get the sw installed? Can you confirm it's working without replacing the usb cabling?
Having read your post, I ordered and installed the usb hub and it's working fine for music (I bought a used part for 60€), but for Android Auto I got a quote from local dealer of about 500€ only for the sw update (they charge 400€ just for 31659192), when the full retrofit kit installed costs 600€. I'm feeling very sad...
The strange thing is that my car (2016 XC90) already has Apple Carplay as an option, but they ask additional money for Android Auto sw (I thought it was free, provided that the car has the smartphone interface option).
Very very confused...
1 - 20 of 23 Posts
