Hi
The screws that hold the vertical "side seat supports" to the cushions have come out. Does anyone know of a fix? Anything I put in there just falls out. It doesnt seem there are threated inserts to hold the screw. Without the screw holding the cushion on, the seat just falls backwards.
Thanks
Mark
There should be a threaded insert in there of some kind. I just pulled one of mine out and it's 1/4-20 thread by 1-1/4" long. It's a fairly big screw and it takes some length before it finds threads to engage, so it does need to be pretty long.
If a long screw of the right thread doesn't bite, then the threads are stripped or whatever nut is supposed to be in there is broken off, and you'll have to remove the seat skin to figure out a solution.
