Howdy,
I have done lots of searching without results. Can anyone assist me? The metal frame that is permanently attached to the bottom of the window has rusted so badly it no longer supports the window inside the door. Fortunately, Agent Strangelove in Oregon set me up with a new used window. Any ideas on how to pull the glass out and put the new glass in the door? It doesnt seem that it will fit through any of the services holes in the door but it should?
Thanks
Mark
Flagstaff, AZ
You have to rotate it 90 degrees and bring it out the horizontal slot in the top of the door that it normally slides through.
