So the good news (I think) is that I have the Bosch alternator conversion. The bad news - which may be a standard thing - is that the alternator when tested today is putting out 18 volts. The 122s is a 12 volt originally (right?) so I need to make sure there is a voltage regulator in the circuit right?
Ideas?
Re: Alternator & Voltage question (tdskip)
It should be putting out about 14V, and that should stay steady at any engine speed. If the voltage goes higher with revs, it's not regulating properly. Does it do that?
Re: Alternator & Voltage question (Phil Singher)
Hi Phil - as always thanks for the help.
Currently (sorry for the bad pun) she is at 18v at higher RPM, on the bench at least.
The local rebuilding shop indicated they could put an internal regulator into keep it at 14.
If the voltage rises with speed, the DF circuit is open. That's the one with the spade connector. If the external wiring on that line is good, take off the phenolic panel around that connector and see if the wire from that connector is good inside the alt -- some have another spade inside that can come unplugged or otherwise fail to make contact.
I suppose it could be a regulator failure, although not a typical one. You can get a solid-state external regulator from IPD and other places that's a direct replacement for the old one. No particular advantage in going to an internal regulator that I can see.
