1 - 8 of 8 Posts
I know. On most cars easy task. On my s60, seems to be down there and not much room to work. I've searched and cant find a thread... Anyone know where to start? Can i go in from the wheel well? Or do i have to try and get my hands down there?
pretty easy, all done from the front of the car
1 disconnect battery
2 remove radiator fan for extra room
3 remove serp belt
4 remove PS pump
4 disconnect lines from the back of the alternator
5 unbolt the alternator ( a couple of bolts on top, loosen bolts shared by the ac compressor
6 remove alternator by moving it to the drivers side along the radiator
install in reverse order, make sure not to spill PS fluid. super flammable
good luck!
edit: you'll need to remove the OTE piping
Thanks dick, was a simple question. Do i go through the top or through wheel well. Didnt need your opinion. Thanks for yours though ASC.
PM me an email where I can send a copy of the VIDAS page regarding alternator replacement.
It can all be done from the top of the car. I lifted mine because I'm taller than most, but not needed
asc answered my question already with the first reaponse. end thread... Thankyou though.
1 - 8 of 8 Posts
