I got a 99 v70r, when I lock it the alarm light doesnot light up that's in the middle of the dash.. Recently my passenger door lock has broken so whether the door lock is up or down the door still opens from the outside.. I don't know of that would effect the alarm or not... I could really care less about the alarm as the car is used to go back and fourth to work and a delivery vehicle for my restaurant:D.
Does anyone have a write up on taking off a door panel? Or does anyone have a write on disabling the alarm? Im asking cause i, not sure of the alarm is draining the battery or not..
When you lock it are you using the remote?
Check the locked car after maybe 10 minutes. Does the dash light blink every 5-10 seconds?
I'm using the key as the remote battery is dead.. But in the past whether I used the remote or key the light always would turn on.. Ill lock it and go out after a Lil to check to see what you said...
As for lock replacement, it is quite easy. You will need a few torx wrenches.
Ipd has a write up. Also you can search for youtube for video guides.
