1 - 12 of 12 Posts
anyone experienced a loud constant roar at high speed?<br>seems now to be beginning at lower speeds too.<p>put summer tires and wheels back on and now completely gone.<p>bearing? differential?<br>
Re: aircraft roar from rear (roadrosen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>roadrosen</b> »</i></TD></TR><TR><TD CLASS="quote">anyone experienced a loud constant roar at high speed?<br>seems now to be beginning at lower speeds too.<p>put summer tires and wheels back on and now completely gone.<p>bearing? differential?<br></TD></TR></TABLE><p>did you just answer your own wuestion? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>roadrosen</b> »</i></TD></TR><TR><TD CLASS="quote"><br>put summer tires and wheels back on and now completely gone.<br></TD></TR></TABLE><p>self-diagnosis is a beautiful thing <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>roadrosen</b> »</i></TD></TR><TR><TD CLASS="quote"><br>put summer tires and wheels back on and now completely gone.<br></TD></TR></TABLE><p>Worn / Cupped winter tires.<br>
Re: aircraft roar from rear (r_driver04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>r_driver04</b> »</i></TD></TR><TR><TD CLASS="quote">Sounds like a wheel bearing.</TD></TR></TABLE><p>could also be your angle gear acting up... that is what mine did, and I brought the car in, they said they put it up on the lift and couldn't turn the rear wheels by hand, the angle gear was basically destoyed, but I still had AWD, so it wasn't totally gone. Anyway, it's a possiblity.
Banned
Re: aircraft roar from rear (JOSBRO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JOSBRO</b> »</i></TD></TR><TR><TD CLASS="quote">could also be your angle gear acting up... that is what mine did, and I brought the car in, they said they put it up on the lift and couldn't turn the rear wheels by hand, the angle gear was basically destoyed, but I still had AWD, so it wasn't totally gone. Anyway, it's a possiblity.</TD></TR></TABLE><p>To test IF it's the angle gear...press clutch and if the sound goes away, it's the angle-gear, if it stays most likely it's a wheelbearing (or cupped tires)...can't imagine the rear-diff already goes.
I, too, sometimes experience an aircraft roar from my rear. It usually prompts all of the windows to be lowered.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>roadrosen</b> »</i></TD></TR><TR><TD CLASS="quote">anyone experienced a loud constant roar at high speed?<br>seems now to be beginning at lower speeds too.<p>put summer tires and wheels back on and now completely gone.<p>bearing? differential?<br></TD></TR></TABLE><p><br>It could be a wheel bearing if the noise persist despite the change in tires. Hopefully not the angle gear w/ so few miles. Which is less expensive to fix a wheel bearing or angle gear?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>r_driver04</b> »</i></TD></TR><TR><TD CLASS="quote"><p><br>It could be a wheel bearing if the noise persist despite the change in tires. Hopefully not the angle gear w/ so few miles. Which is less expensive to fix a wheel bearing or angle gear?</TD></TR></TABLE><p>I went from my Alpins to Rosso's a couple months ago and had the <I>exact</I> same noise. Mine started at about 30 mph and was there all they up past 100, the stereo would not cover it up so it was very annoying. Dealer "fixed" it they said but I pulled out of the lot and turned right around. Took the shop foreman for a ride and diagnosed it as a right rear wheel bearing. Brought it in the next week and she's now quiet.<p>This was with about 10.5k on the clock too <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"><p>My guess would be a bearing. Take 'em for a ride <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
1 - 12 of 12 Posts
