anyone have any pros or cons for putting in a one way rubber valve on the airbox?
i have a 2.5T but was curious if i put a rubber valve in that would be stiff enough to stay closed on nomal use but would open to allow more air when i accelerate beyond the normal.
Re: Airbox Valve... (DGBibo)
The R's already have one of these. It is set to open at a pretty high vacuum, designed to work if the main air scoop is clogged.
You should run a manometer test (make a simple U-Tube water manometer) and test to see if you have airbox vacuum at WOT.
Otherwise it might not be necessary.
