Quote, originally posted by cmurphy2266 » |
Are you talking about the mesh on the MAF? |
Quote, originally posted by xman03 » |
Would it affect the readings without it? |
Quote, originally posted by VolvokidS60R » |
I cauld my friend. Id leave it there if you need more air flow lets port out the charg pipewe can shave about 2-3 mm off it |
Quote, originally posted by Needsdecaf » |
Yes. To what extent, I don't know, but yes. If you want to get scientific about it, you'll need some instruments. Make a manometer using a water tube and drill a port post-MAF. Take a reading with and without the screen and let us know if it helps things. i'm guessing no, but you never know. Also, it would be prudent to run some kind of scan tool to measure how it affects performance. Bottom line is it's there to clean up airflow and help the MAF sensor work better. Given the size of the mesh it's probably not much of an impediment. |
We already shaved some from the outside, it's gonna be as thick as a soda can if we port it ![]() - Looked at some other forums, seems like a good idea to leave it on. O well. |
The issue is people having negative pressure in the airbox especially tuned so I was thinking taking out the plastic mesh would aleviate the problem. . |
Quote, originally posted by Oceans60R » |
I've removed mine before and can confirm it WILL set codes. Specifically MAF Flow too High. So back in it went. It only took a very short trip to get the MIL and surged and bucked under boost. |
Quote, originally posted by -Pascal » |
This is the expected result. The grid is called a flow straightener, it helps distribute the flow across the surface of the pipe so that the tiny sampling area of the MAF sensor actually represents what is happening, as accurately as possible. With turbulent flow across the MAF if your intake setup sends a stream into the tiny sensor but other parts of the pipe are seeing less flow the reading will show more airflow than actual. Vice versa if that "jet stream" of sorts avoids the sensor area, it would get into the engine unnoticed (i.e. with incorrect fueling to match). Leave the flow straightener in place. ![]() |
